AIF XML Statements
I’m attempting to produce an XML file with the same data as is in the external statements report. However, I was expecting to find the transactions in CustTrans, but it seems not. Can someone please tell me where they are.
I guess I need a query on Custtable and wherever the transactions are and then use the AIF document service wizard to produce the XML file. Is this the correct way to proceed do you think?
The data must be somewhere because the external statement shows results.
Yes, you need to do that.
However it would be helpfull for you to follow some guidance first. Take a look at the AIF framework chapter in the book Inside Microsoft Dynamics Ax 2009
