I use AX 2009. I installed AIF Web Serivce on IIS, I added web service site address to AIF form and validation passed.
I try to use out of box CustomerService. I created endpoint with wsHttpBinding binding. When code is executes I get error with problem to call CallStaticClassMethod. I also setup BC configuration. Below I attached web.config, C# code and error text.
https://onedrive.live.com/?cid=0AE7867F90F4DB32&id=AE7867F90F4DB32!257
best regards,
Jacek
