Hello,
Using the AIF wizard, I have created a document service based on a query with the following data sources:
CustTable → DirOrganization → PartyLocation → LogisiticsLocation → LogisticsPostalAddress (all inner joins except an outer join for DirOrganization → PartyLocation)
When I try to issue an update operation against the AIF service, I receive the following error:
"No valid document identified from the entity key."
I’m using CustTable.AccountNum as the EntityKeyField.
Upon debugging the service code, the error is produced in the method, AxdBaseUpdate.buildStructuredDocumentEntityKey(). The line this.buildStructuredDocument(_localQuery) results in a NULL ‘document’.
I’m not sure why the above line doesn’t return a result? Looking at _localQuery the conditions and joins seem correct and should return a result.
Does anyone have any ideas what is causing the error? Maybe there is a problem with the query?
Nick
