I’m trying to deploy a service in the AIF but I get the following errors:
‘Cannot create a record in SysXppAssembly (SysXppAssembly). The record already exists.’
‘Service generation may fail because the incremental build has failed.’
My service then seems to deploy fine but I don’t think it has worked as any changes I make to the schena aren’t there, it seems to be stuck at a previous deployment.
Did you try generating full CIL if the incremental build fails?
Hi Vass,
Please follow below steps it may help you
1. Stop AOS.
2. Delete all files from path C:\Program Files\Microsoft Dynamics AX\60\Server<>\bin\XppIL.
3. Start AOS.
4. AOT > Add-ins > Incremental CIL generation from X++
Simply go to the Developer Workspace and choose Build > Generate Full CIL from the top menu.
Hi Jagannath,
I tried the steps you mentioned but got the same error so I’m going to do a Full CIL as suggested by Martin
