Hi
I have created a new AIF service using Tools → Application Integration Framework → Create Document service. In the query I have used Ledger JournalTable and LedgerJournalTrans as datasources. I have deployed the service. When I try to use the service in Excel Add in its giving the following error.
This may not be the issue with AIF service but an issue with Excel add-in. Just to be double sure, have you tested the AIF service first without using Excel add-in?
