- Created AIF web service in axapta 2009 2) Need data insert into external database table from ax database via AIF web service using c# Please any one help Thanks in advance! Mani
For reference, the previous thread about the same.
Manikkam, you haven’t got any more specific answer than I gave you last time because you haven’t asked any question. Do you think that repeating the same approach will work better this time? I believe you should rather explain what exactly you need a help with.
