I can’t seem to enable parallel processing for NetTcp inbound ports.
I’ve setup an Enhanced inbound port, and checked “Process requests in parallel”, but when I Activate the port AX automatically unchecks this value. Is this a limitation of the NetTcp adapter or do I need further configuration?
We operate two AOSs but they are not load balanced. All our AIF calls are sent to AOS1.
Running Dynamics AX 2012 CU5
