Can anybody tell how to connect the AIF in axapta to .NET Application(Both axapta and .NET application are from different database).I want a solution as soon as possible.Pls help me in this.
Pls help me soon in the AIF Integration with .NET Application
Hi SriLakshmi,
Download the Aif Configuration file from this link:
The second link i am having already.The first link i cant open it.I want info related to AIF Integration with .NET Application(where two applications should be from two different database)
Thanks for your info.I asked for DOTNET Application not a .NET Business connector
Look at the MSDN article which has example of calling AX AIF web service from C# to create a sales order - http://msdn.microsoft.com/en-us/library/ff628055.aspx
What exactly are you trying to achieve?
Thank You for your information.I will check it and tell u.But i want some info regarding if suppose Microsoft Dynamics Ax is from one database and DOTNET is from another database then how to integrate them using AIF.
