We have a AIF Service (WCF) in AX 2009 which receives some data from an external system(Client), updates DAX and returns the number of records updated.
Occasionally, the client returns the error “An existing connection was forcibly closed by the remote host”. When we look at the data in DAX, it appears to have been updated successfully. Also, our process saves copies of the request and response messages on a network directory, and the response message is not showing up when this error occurs.
We have two AIF servers which are load balanced, so we thought that might be a factor, so we changed the config on the client to always send the requests to a specific AIF server, but we still get the errors no matter which server we point to.
Again, the error does not occur every time. Over the last year or two, there have been times when we only see it once a month, and other times it will occur several times a day. The last few days we’ve been seeing it on about 50% of the requests, which occur every 10 or 15 minutes.
Need help to fix this issue thanks in Advance…!
ACTUAL EXCEPTION (ERROR) MESSAGE :
- Exception System.ServiceModel.CommunicationException: An error occurred while receiving the HTTP response to http://myservice.svc. This could be due to the service endpoint binding not using the HTTP protocol. This could also be due to an HTTP request context being aborted by the server (possibly due to the service shutting down). See server logs for more details. —> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. —> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
— End of inner exception stack trace —
at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead)
at System.Net.HttpWebRequest.GetResponse()
at System.ServiceModel.Channels.HttpChannelFactory`1.HttpRequestChannel.HttpChannelRequest.WaitForReply(TimeSpan timeout)
Server stack trace:
at System.ServiceModel.Channels.HttpChannelUtilities.ProcessGetResponseWebException(WebException webException, HttpWebRequest request, HttpAbortReason abortReason)
at System.ServiceModel.Channels.RequestChannel.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.SecurityChannelFactory`1.SecurityRequestChannel.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Dispatcher.RequestChannelBinder.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Director.UpdateIds(Update.ServiceIdsRequest request)
at ClientDirector.UpdateIds(Update.ServiceIdsRequest request) in c:\ABCDirector\Service \Reference.cs:line 1523
at Director.DAXUpdateServiceIDs…Client.Update.ServiceIds(Axdabc.DaxSvcId abc.DaxSvcId) in c:\ABCDirector\Service \Reference.cs:line 1529
at Director.GetNewOrUpdated.sFromDaxTransaction.Send.ServiceIDsToDAX(TransactionDetail requestTransactionDetail) in c:\ABCDirector\ABC.Director\GetNewOrUpdatedDax.cs:line 247
Exception Message An error occurred while receiving the HTTP response to http://myservice.svc. This could be due to the service endpoint binding not using the HTTP protocol. This could also be due to an HTTP request context being aborted by the server (possibly due to the service shutting down). See server logs for more details.
Exception StackTrace
Server stack trace:
- Exception System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. —> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
Exception Message The underlying connection was closed: An unexpected error occurred on a receive.
Exception System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
Exception Message Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
Exception System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host
- Exception Message An existing connection was forcibly closed by the remote host
