hi,
I would like to consume AIF WebService CustCustomerService. Below is my c# code. I get error when executing code.
What I should to do to resolve my error?
AIF Exception form
Element ‘MessageParts’ with namespace name 'schemas.microsoft.com/…/Message’ was not found. Line 1, position 2.
custAif.CustomerServiceClient proxy = new custAif.CustomerServiceClient();
custAif.QueryCriteria qc = new axAIFWebService.CustomerService.QueryCriteria();
custAif.CriteriaElement[] qe = { new axAIFWebService.CustomerService.CriteriaElement() };
custAif.EntityKey entityKey = new axAIFWebService.CustomerService.EntityKey();
qe[0].DataSourceName = “CustTable”;
qe[0].FieldName = “AccountNum”;
qe[0].Operator = axAIFWebService.CustomerService.Operator.Equal;
qe[0].Value1 = “OPO9999”;
qe[0].Value2 = “OKR0247”;
qc.CriteriaElement = qe;
custAif.AxdCustomer custTable = proxy.find(qc);
proxy.Close();
What’s the purpose of the empty entity key? Isn’t it cause the problem? And why did you set Value2 if there is no range?
Try to fix these things first - even if it doesn’t resolve the problem, you’ll get better code.
BTW you can avoid prefixing all types with custAif by adding using custAif on the top of the file.
I copied example from MS sites. MS use method findkey and they need EntityKey.
I commented entityKey and value2 but I still get error.
Maybe do you have working example how to consume AIF WebService?
I don’t have any AX 2009 on hand in the moment, but this works fine in my AX 2012:
CriteriaElement element = new CriteriaElement()
DataSourceName = "CustTable",
FieldName = "AccountNum",
Operator = Operator.Equal,
Value1 = "US-001"
QueryCriteria criteria = new QueryCriteria()
CriteriaElement = new [] { element }
CustomerServiceClient client = new CustomerServiceClient();
AxdCustomer customer = client.find(new CallContext(), criteria);
@Martin I get the same error with your code.
I reviewed once again AIF configuration and I think it is ok. I supose there is problem with my c# call.
Below is schema for find customerService
<?xml version="1.0" encoding="utf-8" ?>
- <xsd:schema targetNamespace=“http://schemas.microsoft.com/dynamics/2006/02/documents/QueryCriteria” xmlns=“http://schemas.microsoft.com/dynamics/2006/02/documents/QueryCriteria” xmlns:xsd=“http://www.w3.org/2001/XMLSchema” elementFormDefault=“qualified”>
<xsd:element name=“QueryCriteria” type=“QueryCriteria” />
- <xsd:complexType name=“QueryCriteria”>
- <xsd:sequence minOccurs=“1” maxOccurs=“unbounded”>
<xsd:element name=“CriteriaElement” type=“CriteriaElement” />
</xsd:sequence>
</xsd:complexType>
- <xsd:complexType name=“CriteriaElement”>
xsd:sequence
<xsd:element name=“DataSourceName” type=“xsd:string” />
<xsd:element name=“FieldName” type=“xsd:string” />
<xsd:element name=“Operator” type=“Operator” />
<xsd:element name=“Value1” type=“xsd:string” />
<xsd:element name=“Value2” type=“xsd:string” minOccurs=“0” />
</xsd:sequence>
</xsd:complexType>
- <xsd:simpleType name=“Operator”>
- <xsd:restriction base=“xsd:string”>
<xsd:enumeration value=“Equal” />
<xsd:enumeration value=“NotEqual” />
<xsd:enumeration value=“Greater” />
<xsd:enumeration value=“GreaterOrEqual” />
<xsd:enumeration value=“Less” />
<xsd:enumeration value=“LessOrEqual” />
<xsd:enumeration value=“Range” />
</xsd:restriction>
</xsd:simpleType>
</xsd:schema>
Here is document history form Basic/periodic/AIF/Document history
<?xml version="1.0" encoding="UTF-8" ?>
CustTable
AccountNum
Equal
US-001
Document format is ok?
