As we are migrating from AX-2009 to AX-2012R3, but after complete test migration AX-2012 not showing some of our data like Customer Master, Vendor Master and Employee that was in our AX-2009.
now we stuck with it till it shows, is there any one who can help us in this regards.
Didn’t you get any errors during the data upgrade?
Also, you surely can extend your analysis from “isn’t showing” to something more specific. For example, if you see the data in table browser but not in a form, the problem is likely in some missing reference data. If you see the data in database but not in table browser in AX, you might have a problem with partitions or data areas.
I already told you what to analyze first. It will help you to isolate the problem and it might make the cause obvious. If it doesn’t you’ll have to do some additional analysis. If you don’t succeed by yourself, tell us what’s you’ve found by the initial steps.
You also haven’t answered yet whether you got any errors during the data upgrade.
