Anyone knows how to do it?
Use Tools, Navigation Pane Designer or Alt+F12.
Select the pane / module to modify; then navigate to the section where you want to show the new object. The righ-click on the mouse and you have an options menu;create, insert, create group and others.
Use create and you have a small windows to enter the Object Type, Object ID and a caption (different from the Object Name).
Use insert if it is an object in the “standard” system.
Is that OK?
