I don’t know if this is possible, but when you are at the last column and push tab, you will be back at first column and then you can simply push the arrow down key to be in the next row.
I couldn’t find the way to do what I asked here. But turns out I didn’t need exactly this. I needed to move the focus to first field of the next record when the last field was changed. I just overrode the modified() method of the last field control, used this code and it worked.
