how to get the date value specified in the advanced filter?
and how can i use that date to filter the records that will be retrieved?
To set a filter, just type in a date in the format defined in Windows and use the usual operators. E.g. >21/04/2014.
You’ll see the value in the form with advanced filters.
I mean if i select a date like this and press ok.
how do i retrieve the value of that field?
like in the picture how will i get 5/27/2013?
Aha, so this is not about normal ranges, this is about data effective data.
Get the instance of the query and call validTimeState*() methods, such as validTimeStateAsOfDate().
