AdressRefTableId in PurchReqLine table
Dear all,
I face a problem. When i select the table purchreqline and found the addressreftableid field is 2477.
Usually if the addressreftableid field is 1555, it means that the RFQ is made from Purchase requisition. How about table id 2477.
Thanks in advance
Didn’t understand exactly what you are query is.
But, table id 2477 is for PurchRFQCaseTable i.e., request for quotations
For reference, 2477 is ID of PurchRFQCaseTable.
Hi, Sorry for the late respond
Actually i’m going to test the RFQ which is copy from PR.
If the PR is copy to RFQ the addresstableid in RFQcaseline table will be 1555.
But i’ve check some RFQ data , some of them if 2477. But the rfqcaseid is recorded in purchreqline table. And the PR still can create RFQ. Usually if the PR only create RFQ one time.
Thanks in advance
Regards
In the RFQ, Address tab you can add address from other record types(click on other address). Here you can set the record type to Request or quotation and copy the address. Even in this case the AddressRefTableId will be the same as table id of copied from table.
Dear Kranthi,
Thanks for your info.
