Administrador no se puede importar usuarios en DFO "Acceso Requerido" Ambientes DEV
Hola!
Por favor alguien sabe cómo se puede resolver el error al importar un usuario en sistema DFO, con usuario administrador de un entorno DEV. En ambiente Sandbox y Productivo no se da el problema.
Existe la posibilidad de crearlo manualmente, pero requerimos que se cree el ID de Telemetría.
Hi @Claudia_Contreras_Ve
This is a DEV environment-specific permission issue, not a global account problem.
Why:
Your admin account works in Sandbox and Production, but DEV has different security/role configuration blocking user import.
Solutions:
1. Verify System Administrator Role in DEV
  • System Administration → Users → find your admin account
  • Confirm “System Administrator” role is assigned in DEV
  • Re-assign if needed
2. Check User Import Security Privilege
  • System Administration → Security → Security roles → System Administrator
  • Verify “User import” privilege is enabled
  • Enable if disabled
3. Compare DEV vs. Sandbox Settings
  • System Administration → Environment
  • Verify DEV security setup matches Sandbox (which works)
  • Align configuration
4. Azure AD Sync Configuration
  • System Administration → Azure Active Directory applications
  • DEV might have different Azure AD settings
  • Verify app registration matches other environments
5. Clear User Session Cache
  • Sign out from DEV completely
  • Clear browser cache
  • Sign back in and try import again
Key Point:
DEV’s role/security configuration is the issue. The other environments work fine, so your account has proper global permissions.
If you need help troubleshooting your DEV environment, let us know.
Email Here
