Good Morning-
Not sure if this is the right forum but, my client is on 4.0 sp1. They imported a large number of items into their existing system and ever since then, they cannot run Adjust Cost. It never finishes. They let it run for 32 hours over this past weekend and it just keeps going.
I can’t imagine it should ever take that long when they have Automatic Cost Adjustment turned on. i think it’s in a loop due to a problem with these imported items.
I’ve looked at the items and they are missing a few fields but, I’m not sure if that has anything to do with it. The Rounding Precision was set to zero. I changed that on my test database to 1 but it didn’t seem to make a difference. Although, in all honesty, I only let it run for 2 hours.
There is a field called Allow Online Adjustment. I have no idea what that is for but all of their original items have it checked and the imported ones do not. Does anyone know what that does? Could this be causing things to hang? I can’t easily change that field. It won’t let me do a find and replace.
If anyone has ANY ideas as to what could be happening here, i would appreciate it.
Diane
