Hello, One of my client uses Serial Numbers and Lot numbers for Inventory with Specific costing method. It is taking us to Run adjust cost item entries Batch job around 6 hours to complete. Has anyone encountered this problem in Version 3.70 and is there a solution to reduce the time. Please help Kartik
Hi, Are you running first time? How much data you have, I mean after how many months you are running this routine? If you are running monthly then it will not take much time.
Hi, I have a customer who has similar problems. They are pushing a lot of items with serial numbers and the routine took a lot of time. Now we are using the application server to update every day so it’s not a problem during the day. Best of luck,
Don’t worry. We have customers that run the batch job sometimes for more than 8 hours:) You can try to optimize your tables in File-Database… before running the batch job
