How to add field values to combobox in AX 2009 where field type is string.
Ambanna Yatnal
Ambanna Yatnal
Cerate a Base Enum…
Hope this would help you
Regards
Kranthi
No Kranthi,
I need to fill the data from some tables. say Field1 from Table1. How do I add all field1 values to combobox?
Ambanna Yatnal
sorry
I didnt get you
can you eloberate it
Regards
Kranthi
Ok.
Say i’ve employee table, I want to add all the employee name to combbox, so that user can select perticular employee in dialog and he can see particular employee details by clicking OK button.
Ambanna Yatnal
Add dialog field like this,\
dialogField emplId1;
emplid1 = dialog.addfieldvalue(typeId(EmplId),emplId1,“employee”,“Select Employee”);
Hope this will help you
Regards
Kranthi
Hi Ambanna,
In case of employees, just use EDT ‘EmplId’.
For an example, please click here - http://www.axaptapedia.com/Dialog. This example shows how to select and return a value.
try this:
Dialog dialog = new Dialog();
DialogField dialogField;
FormBuildComboBoxControl formComboBoxControl;
// Any enum, except NoYes, will do.
dialogField = dialog.addField(typeId(ABC));
formComboBoxControl = dialogField.control();
formComboBoxControl.enumType(0);
formComboBoxControl.label(“My combo box”);
formComboBoxControl.items(3);
formComboBoxControl.item(1);
formComboBoxControl.text(“Item 1”);
formComboBoxControl.item(2);
formComboBoxControl.text(“Item 2”);
formComboBoxControl.item(3);
formComboBoxControl.text(“Item 3”);
dialog.run();
hope this will help you.
link: http://blogs.msdn.com/b/palle_agermark/archive/2005/06/30/434146.aspx
Hi ,
Design the form with required fields for lookup, and copy the form name…and go the table of ur field where u hav the field …in the properties of that table paste the copied form name in the form ref property…For reference u can check the ‘Job details’ form in HR module
