Now I am doing the Sales invoice Report customization in AX 2012. I am adding some fields like customer Email,phone… etc, in SalesInvoiceTmp Table. I am getting one error while adding these fields.
The internal size of a SalesInvoiceTmp record is 24616 bytes, but MicroSoft dynamics is by default Performance-tuned not to exceed 24576 bytes
It is strongly recommended that you split your tables into smaller units.
Alternatively, you have to specify a ‘Maximum buffer size’ value of 25 Kbytes or higher on the ‘Database Tuning’ tab page in the Microsoft Dynamics AX Server Configuration Utility. The default value is 24 Kbytes.
4.Exit Microsoft Dynamics immediately, and follow the directives above. Use of the table(s) will cause unpredictable results.
We increase the Tmporary table Buffer size? and It will give the correct results or not?
Another way of adding the fields in this table. Pls help me how to do this.
Balu
