Adding ODBC driver to Citrix
Has anyone added Navision ODBC driver to Citrix?
I have installd it on both Winframe and MS Terminal Server 4.0. BUT not without problems :~) If Citrix is installed on an NTFS partition (as it usually is)you get an error : “Date is not valid”. Three files are installed without date : codbc.etx, codbc.stx, codsql.dll. You have to use a trick like this to make it work copy /b m:\winnt\System32\codbc.stx+, Do this for all 3 files and it should work.
