Adding More Fields in Fixed Assets Card
I am trying to add some new fields in Fixed Assets Card. I added the Fields in table 5600 Fixed assets. Then tried adding the fields in Fixed assest card 5600. But I am not able to access and link the columns just added. Should fields be added in other tables also ?
PS: Working in NAV 2013
regards
mahesh
Did you try by restarting the NAV Server?
Hi Mohana,
I could not access the columns from the designer window. I cannot add the columns in the page. While adding extra fields in FA Card, is it only fixed Asset table 5600 that should be changed ?
regards
Mahesh
What do you mean by Design Window?
Can you be able to open table/page in design mode?
