How do you add a logo to the check so that it is clear. I have the logo and it is very clear under paint. However, when I import it in as a blob or just add it to an image box, it becomes distorted. Are there any tricks to this?
Hi David, Before importing change its resolution.This will help u in getting a clear image on form or report. Regards Rajesh
Hi, It looks a unique problem as i have used it number of times.both in reports and forms. just check it out whther u have imported it correctly in the BLOB field. cheers
another choice is have the logo already on the blank checks. www.compuchecks.com allows you to send them your logo and they will add it to your blank checks free of charge.
