I have created a Date field on salesOrderLine , now when an item is added to a line auto populate the date field as
Date field = sys date() + Item coverage production time
I have added following code in salesline modified field along with my query as :
Case fieldnum(SalesLine, PlnDate):
this.PlnDate = today() + (How to call Item coverage production time from Item coverage form);
break;
kranthi
#2
This has been discussed here, http://dynamicsuser.net/forums/t/86292.aspx?PageIndex=1
you need to get this from \Data Dictionary\Tables\ReqItemTable\Fields\LeadTimeProduction
You are modifying the plnDate and updating it again after the modification?
