Hi
In the Nav2013 dev environment, on a page I have tried to add a field from another table.
I added the item table into the C/AL symbol menu via the C/AL Globals as a variable (not sure if this was the right thing to do).
Anyway, I added this, then the item table fields were available, however when i added it in design, the field appeared blank.
Have I gone about this incorrectly?
neilgf
August 13, 2015, 9:57am
2
James
Hi! Have you created a link to the other table? You need to tell Nav to find the field from the other table somehow. [:)]
Hope this helps.
Neil
neilgf
3
James
Hope this helps.
Neil
Hi Neil
I thought this was my mistake. New to this you see, how would i go about doing that.
James
neilgf
August 13, 2015, 10:09am
5
James
Quite understand! You need a common link between the tables and then add some setrange code OnAfterGetRecord. Have you coded in C/Side before?
Neil
Hi Neil
No i have not. The table i want to add the field from is the item table and the fields i want to add are named blocked and discontinued.
The fields in their orignial table are set to boolean.
If you could advise that would be great. Let me know if you need any more information.
James
Hi Neil
Sorry, when i am the designed and right click and select C/AL code (after adding the field) i get the attached screen, which one of these would i put the code in?
James
neilgf
August 13, 2015, 10:25am
8
James
Can you send me the object (export from development environment) you are trying to amend / create and I will look at?
Neil
neilgf
9
James
neil@fpconsult.co.uk
Neil
