Hello,
I have added a new text field to the PurchLine table for technicians to add the purchase requisition line related notes. We would like to show these notes on the PO report.
I am following the following link for the work involved.
http://amberax.blogspot.com/2018/05/ax-2012-adding-field-to-purchline-and.html
This is what I have done so far:
added notes field to the PurchLine.Ext
added notes field to the purchPurchaseOrderTmp.Ext
Added notes field to the purchLineHistory.Ext
Updated PurchLineArchivedVersions.Ext view and PurchLineNotArchivedVersions.Ext view
Built the solution successfully.
I am stuck at the next step where I have to compile the PurchLineAllVersions view
I have created an extension PurchLineAllVersions.Ext but since this view uses base views PurchLineArchivedVersions and PurchLineNotArchivedVersions as datasource, my notes field is not showing up and I cannot add it to the fields of this extension. I am not sure how to go about doing this work.
I need to make sure the new field is in PurchLineAllVersions so I can add it to the PurchPurchaseOrderDP
Any help is appreciated!
Thank you.
