I am working on SalesSalesInvoice.read services and want to create a new field say Barcode and show the value on the outbound XML file.
I have created Barcode field in the CustInvoiceTrans Table and have compiled and Barcode is showing on my data policies.
But I was wondering if you can help me which class should I use to insert the value of the Barcode so that when I generate an XML file Barcode has the value which I declare.
It will be of great help if you can name the class and method for me on which I can work.
Thanks.
