Add columns by another table rows.
Is that any way to add columns in one table by another table rows.
ex: i have created a table “Test” and i have a navsion table SalesPerson,. Now i want that when i add a new sales person, that sales person should add automatically in the Test table as a new column.
Is that any way?
Thank you.
Regards
Do you mean new column means new field ?
Yes
You can try this code in OnInsert trigger of Sales Person/Purchaser table.
Field.RESET;
Field.SETRANGE(TableNo,69000);
IF Field.FINDLAST THEN BEGIN
Field.INIT;
Field.“No.” := Field.“No.” + 1;
Field.FieldName := Code;
Field.Type := Field.Type::Code;
Field.Len := 20;
Field.Enabled := TRUE;
Field.INSERT;
END;
Where field is a record type variable of type Field
No, that’s a really silly idea. If you are trying to setup a relation table then create a table with a primary key of salesperson code and add code to the OnInsert / OnRename triggers of the salesperson table.
In the scenario you describe, you could easily run out of fields. There is a limited record size. If you need a new Field, manually add it via Object Designer. If you need data automatically populated in a field, you should use the correct triggers.
