Hi to All,
Unable to add and delete the Security Roles and Security Privileges in Form level.
Form Path:System Administration->Setup->Security->Security Roles
Form Path:System Administration->Setup->Security->Security Privileges
There is no Customization in that form’s.
Please Suggest the Solution.
Thanks and Regards
Muthusamy
Do you have sufficient permissions? Don’t you have enabled a version control system?
Check do you have the security Admin role & System Admin role.
Friends Thanks for the reply.
I am having the full Permissions(System Administrator Role).
Version Control System is Enabled
can you share the TV, if its ok with you my skype id is : jaleel.riyadhksa
You’ll have to disable the version control and add the changes there manually.
Could you please mark the answer, so it’s clear that this thread is closed and that people can find the answer in future? Thank you.
