Add a Route button in Pickinglist journal to open route card journal
I need to add a button in Pickinglist journal form to open Route cardjournal.
May I know how to do that?
Thanks.
Hello,
You can create a new display menuItemButton and call the Route form in the object of the menuItemButton.
There i need to add a button to open routecard journal from this form.
Thanks, Wikey
This form needs to open when i click tat button.
I checked those menuitem assigned for that it showing like this,
Hello,
Please see the below screenshot, This is were you need to creata he new menuItemButton,
ProdJournalTable → Design → Tab → ButtonGroups. Create a new menuItemButton and tag the created menuItem in the property of the button.
Yes, I created tat button and in clicked method i called that menu item
void clicked()
super();
new MenuFunction(menuitemdisplaystr(ProdJournalTableRouteCard), MenuItemType::Display).run();
Now the thing is its opening routecardjournal but in routejournal also tat button is visble, i need to hide that
How should i do that?
Hello,
Insert this code in the init method of the prodJournalTable form,
if(element.args().menuItemName() == menuItemDisplayStr(ProdJournalTableRouteCard))
MenuItemButton.visible(false);
MenuitemButton is the name of the button you have created in the form. Make sure you have changed the autodeclaration property of the button to YES.
Thanks, Wekey.
