Hi! Can someone tell me where i can find some books in pdf about ADCS? Does it existe? What hardware I need for using ADCS?
I found a file called w1w1InstADCS.pdf on the product CD. Read that along with the NAS manual should allow you to get it working with HyperTerminal acting as the PDT emulator. As for hardware, it appears that you can use any PDT that can connect to the LAN and which has a VT100 emulation mode. I am currently waiting to borrow a Datalogic DL9600 Viper for an evaluation. Allegedly, this has an 802.11 connection so I should be able to connect to my PC via the office WLAN access point. I’ll let you know how I get on. Cheers, John
