When I try to access ADCS through Hyper Terminal, It shows me connected on Status Bar but it is not showing me the login interface. Please advice what could be wrong?
i have the same problem, some help?. thx
Once I got similar kind of problem, but that time Login Window was hidden in the back of the other windows.
It can be for a variety of reasons. We’re using 3.70a and it works pretty well: -Make sure the company name is correct in the Application Sever -Make sure the Start Up Parameter = ADCS ADCSID=NAS1 -Make sure you have the login miniform marked as the “Start Miniform” Let me know if this helps at all… I’ll try to think of anything else we encountered.
