Activity Report?
I want to design a report,in such a way…
My filter element in report will be “ProjID”. whn i select the project Id,i need to display all the “Activities”, related to tht project.
How can i achieve this?
Rajee
There is no direct relation between ProjTable and smmActivities table.
There is another table which form indirect relation between them - smmActivityParentLinkTable
so try to get a report from these tables - by looking into the relations between them…
Ok Kranthi,i found out and got the activities,
but i need to display in the Report as we see in the “Activity Breakdown” structure…in the projTable Form…
i.e . i want as ‘Levels’ … (1) Main project…next (2) sub project … (3) activity
The parentId field in the ProjTable table shows you the difference between the main project and sub project.
if the parentId has no value - which means that it is a main project and not a sub project of any project
if it has some value - which mean that it is a sub project.
Based on that, I hope you can get a report of your requirement…
will i be able to get the "Tree Structure " in report?
I don’t think you can do that - never tried before…[:)]
Ok, is there any way to display like “Steps” ?
I’ve found out a small clue on how the tasks are displayed in tree structure “In ‘HierarchyTreeTable’ ---- the ‘ParentElementNumber’ specifies which tasks belongs to which parent”. Now is there any way to display the activities in a TREE LIKE structure in report using this clue?
What is ur clue?
Thanks and Regards,
Kevin
