Hi all I have a strange problem We installed Attain 3.10 at a customer, and every time they want to use the help system, a message box appears asking if they want to accept an unsigned ActiveX object. As far as I can see it could be the Company Notes control that causes this message box. But Iām not sure. We have adjusted the setting in Microsoft Explorer according to accepting and running unsigned ActiveX controls. Have any of you encountered similar problems? Thanks in advance. Michael
Did you find a solution ?
Hi Yes, we actually sorted out the problem, with some help from another NSC and Navision. Do you have a similar problem? Regards Michael
