Hello All, First of all I’m new to Navision database and I have a problem connecting MSASP through C/ODBC. It gives me an error: Microsoft OLE DB Provider for ODBC Drivers (0x80004005) [Navision Software a/s][Navision Attain ODBC Driver]ISAM error My code is: <%@ LANGUAGE=“VBScript” %> <% Set Connection = Server.CreateObject (“ADODB.Connection”) Connection.Open “Report” %> Additional info, in ODBC Manager I have setup a System DSN named “Report”, and pointing to the database named “database.fdb”. Can anyone teach me the proper way of calling the database using the MSASP. I really appreciate everybody’s help. TIA, Jofran
if you had found a solution, can you explain me ? because I have stricly the same error…
