Activate Page Setup
Thank you to everyone here who posts such great information! I can usually find what I need without having to ask.
Here is the situation. We are running NAV 5.0, accessing it through terminal services. NAV lives on a windows box running server 2003. The page setup option under the File menu is grayed out in every screen that I would try to access it from.
Is there any way to activate the page setup option, or to change the defaults on how certain reports print?
Thank you for your help!
Jason
I think those options are for reports only…
If you want to set the margins and etc, you can directly set in form properties…
We are trying to change the printout of a report. The properties that we are trying to change are the page layout, margins, etc. The page setup option is always grayed out even if I am in print preview for a report.
How would I access the form properties to directly set them?
Jason
You should set the page setup before pressing preview when you are in Request form…
Thank you that worked perfectly and it permanently changes the set up of the report which is exactly what I was looking for. Thank you so much for your help
