Action Visibility in Pages
I am finding difficulty in making an action Which is promoted to be made in disabled if it satisfy some condition.
Like what we will usually do in Form
IF Status = Status::Released THEN
CurrForm.Mail.ENABLED(TRUE)
ELSE
CurrForm.Mail.ENABLED(FALSE);
Can we achieve the same thing in pages?[*-)]
In the CurrPage i didn’t find the action which i have given the name property.
Waiting for your valuable replays.
Create a Global Boolean Variable ex: ActionEnable
Set IncludeInDataset property of variable to Yes
Select Action
Set Enable property of tab to ActionEnable
write below code in OnOpenGetRecord trigger of Page
ActionEnable := Status = Status::Released;
Dear Mohana[:)],
The issue is resolved. I have defined one variable like ActionVisible (boolean) and changed the property IncludeInDataset = true.
Then i have the condition is page OnOpen and OnAfterNextRecord triggers which will pass the variable(ActionVisible) true or false. Then i went to the particular action, i have given in the particular action Enable property as variable (ActionVisible). It is working fine[:D].
Thanks a lote for your support[Y].
