Microsoft Dynamics NAV 2009 RTC
I have a strane issue. I create a new Action (DoStuff) on a list page. When I open the page directly, I can click on the small lightning bolt and it pops out the menu and I can run my Action.
However, as soon as I am running the same page as a page part on another page, I can not click the bolt icon. The icon is visible, but nothing happens when I am clicking.
On other page parts I have created this works. Only on this page it won’t.
Can you show a screenshot?
Can you simply add Message(‘Hit’); under the action and try
Well, the problem is, that I can not provide you a screenshot, because there is nothing to see. A click on the bolt icon and nothing happens. Not that the action is hidden, the whole menu does not pop up. It just happens nothing, besides a tiny page flickering.
When I add another list part I created on the same page, the actions work as expected.
If I run the list part by itself (per Run->dynamicsnav://…) I can click the bolt icon and then the actions shows and then I can click the action and the action gets executed as expected.
Ok here are the requested screenshots:
This is the screen after I clicked the bolt:
This is the screen after I clicked the bolt on another page part:
And this is (the left) page when I run it with dynamicsnav://…
Thank you… Its clear now.
Did you try by adding a simple message under action?
The code for both actions Test and newOrder are
MESSAGE(‘Hi’);
I found the error.
The Page , which was included as as sub page was declared as type List. The problems seems to be, that if a sub page is declared as List and not as ListPart, the action button (lightning bolt) does not work and every thing seems to be buggy.
This also happens when a sub is not declared as PagePart but instead as Page.
So, ich changed the declaration to ListPart and now everything works.
