is It possible that when i alick All purchase order link all purchase order should be opened in new window not in the same in axpta 2012 R3.
Not as standard, you would need to customize it, but I would recommend you learn to use the UI given.
You can set the style property of the design node of a form to “Simple List” or “Dialog”.
This will make the form open in new window.
Hi Anand,
its working…
thank u
