Account Structure
Hi I have a query in the account structure, for example same account number range but different dimension will be enable, for example 10000 to 12999 these are my account range, I have 5 dimension combinations, Location, Branches, Division, Sub Divisions & Department, so if I will select Division A then Sub Division & department will appear but if I will select B in Division dimension system will stop to me & not move to sub division & department… Can you please help me Warm Regards MS
Build your account structure only with dimensions that are use in all cases. Dimensions that should occur only at some time (Subdivision and Department in your case) should be added in Advanced rules.
Thanks Martin
I got your idea.
Warm Regards
MS
