Hi All Where I can find description of Navision’s metadata tables? (Tables >=2000000038) Any links or info, please. Andrew Pikunov Best regards, Andrew Pikunov LANIT, Moscow, Russia
The only way that I know to access information about the ‘hidden’ tables is to create a new form and then select the field or objcet table(Or any of the others) as the source table for the form. The field table will give you basic information about the field definitions and data types but as far as I know you canot get to the code on these tables. Hope this helps Rob
