Access the all dimensions in C#
Hello Friends,
I have created a web service in AX and consuming in C#.
Now i want to access the department, Cost Center & Purpose i.e all dimension.
darshana
Hi Darshana,
To access dimensions values, you can use the following code:
Your_Table.Dimension[Dimensions::code2ArrayIdx(SysDimension::Department)]; for department dimension, replace for the others
to update dimension values, specify the array index value you want to update
Your_Table.dimension[1] = …Dimension[Dimensions::code2ArrayIdx(SysDimension::Department)];
Thomas
