Getting this error when I opening a customized report with Accountant role . Same report is running perfectly for “Administrator” rights.
Kindly suggest … Urgent
Is there a [SysEntryPointAttribute] attribute on your processReport() method? Try to set it to [SysEntryPointAttribute(false)], and see if it gets better?
Hi Rahul,
Go to the role → Permissions → server methods. Map the above method and give access. This should solve your issue
Thanks For notify this issue… I got this error long time back and resolved it by adding some server method or some newly created tables in to SSRS - Report - design - permission node. …
Today i got the same error and this time i didn’t use any new table table so i resolved it by given “Delete” permission existing report in same.
