First I need to write or modify records from Navision to Access. What ocx should I use and maybe a simple example. Next (from Navision) I need to read some records in Access and use this information to update certain records in Navision. Again what ocx should I use and a very simple example of the code.
Jason, have a look at the following posts… Navision Financials ADO Example… or Reading Access DB from Navision …or a search in the Integration Forum for ADO will give you good results. Saludos Nils Edited by - nilsm on 2002 May 07 21:48:43
Just a thought: If You’re running SQL it could also be an idea to do the integration om the server. It’s very easy to get access to an MS Access database in DTS-packages. //Lars
