about x++
qbr = qbds1.addRange(fieldnum(LedgerTable,
AccountNum));
please explain me about fieldnum
http://msdn.microsoft.com/en-us/library/aa582184.aspx
this might help you,
please go through this…
FieldNum function - Returns the ID number of the specified field.
int fieldNum(str tableName, str fieldName)
tableName - Table name
fieldName - fieldName
You can look at the below example :
static void fieldNumExample(Args _args)
int myInt;
myInt = fieldNum(CustTable, CashDisc);
Global::info(strfmt(“CashDisc has a field ID of %1 in the CustTable table.”, myInt));
fieldnum will return id of the field in the Table…
For ex:
Check purch table > purchid > properties > Id = 1
