I create a table which have fields1,fields2…fields40 and defines which all fields as a datatype “CODE” length 10.I think in navision the primary key is composed of up to 20 fields in a record,and upto “40 keys” can be associated to table.My problem is after defining that primary key “20 fields”.I cant able to define some other fields as a key.I have no clue about that reason.
ya.,tat may bewrong., the field in active key may not exceed 252 bytes.In my case the field in active key is not exceed 252 bytes its within 252 bytes only,still i cant define some other field as a key.
yes,In Application Designers guide has a following information like “upto 40 keys can be associated to a table”,i tried 20 fields as a primary key,after that i cant able to create a single field as a key.
