about date
Greetings from Nepal to all the experts,
When I close my database it gives me an error message like “Date is not valid”. what is the reason and what should I do to solve this problem.
Please suggest!
Thanks in advance!
Sangam Shrestha
Nepal
Is it version 4? Have you set the time register flag on the user? Unselecting it removes the date - this was a known issue back in the day, so it depends upon your version!
HI
How many companies there in the data base ?
work date should be same for each company
if work date is not same then then the system will pop up an error message
Jerome marshal.J
I was facing same problem
Sangam please change your code of Report No 81 as: this error is due to the date time error.
CODE BEFORE…
ExcelBuf.“Row No.” = HeaderRowNo:
BEGIN
TempExcelBuf := ExcelBuf;
TimePos := STRPOS(TempExcelBuf.“Cell Value as Text”,’ 00:00’); // Time part - only on Service Tier
IF TimePos = STRLEN(TempExcelBuf.“Cell Value as Text”) - 5 THEN
TempExcelBuf.“Cell Value as Text” := COPYSTR(TempExcelBuf.“Cell Value as Text”,1,TimePos - 1);
CASE TRUE OF
TempDim.FIND(’-’):
CODE AFTER…
BEGIN
CASE TRUE OF
TempDim.FIND(’-’):
CODE BEFORE…
EVALUATE(TestDate,TempExcelBuf.“Cell Value as Text”):
BEGIN
TempExcelBuf.Comment := Text014;
TempExcelBuf.INSERT;
END;
CODE AFTER…
EVALUATE(TestDateTime,TempExcelBuf.“Cell Value as Text”):
BEGIN
TempExcelBuf.“Cell Value as Text” := FORMAT(DT2DATE(TestDateTime));
END;
Tulasi (Nepal) :slight_smile:
one thing i missed here is:
TestDateTime is datetime variable not the date variable. Just delete Testdate and Timepos
adam what are the effect if I untick the time register will we not be able to monitor time register of the user?
