Can someone tell me whehter it is possible to set up the ABC Analysis in AX and can we take some reports once we have done this setup
regards
TP
regards
TP
Flag each item on the item record and then run the ABC analysis report.
The periodic routine sets them as well upon the basis you define, but it depends of course if you have transactional data present or not.
Please tell me which field i should flag and how?
regards
Item Details - Other Tab - ABC Field Group.
How depends upon the type of analysis and the setting. If you have been running for a year run the periodic ABC Classification routine.
