A filter question.
I have learned from the beginning that when we are using a filter, the correct syntax is: SETFILTER(“Table_Field”, ‘=%1’, ‘My_Value’) I have just discovered that it’s been a month that I am using filters this way: SETFILTER(“Table_Field”, ‘My_Value’); I know it is not the correct syntax to use, but it seems to work as long as I want to do the ‘=’ operator. Am I violating anything doing this? Thank you for your time.
No violations. You’ll use the first form when you need to do ranges for you are filtering using Option fields. You’ll also use that form when you are filtering for blank values: SETFILTER(“Table_Field”,’=%1’,’’); Cheers, Django
quote:
No violations. You’ll use the first form when you need to do ranges for you are filtering using Option fields. You’ll also use that form when you are filtering for blank values: SETFILTER(“Table_Field”,‘=%1’,‘’);
so far it is ok but you can do also : SETFILTER(“Table_Field”,‘’‘’‘’); for filtering for blank values
quote:
Originally posted by The_Taco
… I know it is not the correct syntax to use, but it seems to work as long as I want to do the ‘=’ operator. Am I violating anything doing this? …
Oups. I’m guilty. I have to admit I never use %1 [}:)]. I sincerely apologize [:p]. Do I have to pay a fine for that?? Or do I loose my developer rights?? bye André
