A dimension used in item journal line ITEM, DEFAULT, 12 has caused an error. Select Dimension Value Code
A dimension used in item journal line ITEM, DEFAULT, 12 has caused an error. Select Dimension Value Code OTHERS for the Dimension Code PRODUCT GROUP for Item CO-ST-0014…
guys we have a customized store requisition and issue module and when we try to post an item issue it shows the above error.We have a mandatory dimension set for every item but on the the store issue line we only find the global dimensions and the dimension in need is shortcut dim 3 how to add it to the line here.
First go to the General ledger setup and in Dimension see what is Shortcut dimension 3 code, then come to the Item journal and then go to the Dimensions on the ribbon and add the Shortcut dimension 3 code and it will allow you to post the journal.
